Текущее время: 11 фев 2026, 15:28
СообщениеДобавлено: 17 янв 2013, 12:36  Заголовок сообщения: ФЭД Атлас Ремонт
Pardon me for not speaking Russian,
I have a Fed Atlas that needs horizontal rangefinder adjustment. How can I do this? Also, it seems that the inside of the removable lens (the screwable element) has been touched. What is the correct possition of that element before attaching it back to the body?
Thank you very much and sorry if I invade your awesome forum,
Nikos.
СообщениеДобавлено: 17 янв 2013, 15:30  Заголовок сообщения: ФЭД Атлас Ремонт
http://rangefinder.ru/club/viewtopic.php?p=93382
СообщениеДобавлено: 17 янв 2013, 15:57  Заголовок сообщения:
Is there any information on the lens? All I have is just a photo from here
http://www.flickr.com/photos/sovietcame ... otostream/
My main problem is that the inner element can be screwed inwards and outwards and I have no reference for adjusting it.
Thank you.
СообщениеДобавлено: 17 янв 2013, 16:57  Заголовок сообщения:
Вообще странно, как можно было написать в правильную ветку не зная русского :)
There is one important rule with all these FED Atlas/10: do not even think about removing the lens from the camera.
Unfortunately, the upper link explains something about vertical adjustment.
And about inner element. You can find its right position by using any DSLR. I think it would be something really bad in wrong position.
Zeiss Ikon Camera,
Zeiss Objektiv,
Zeiss Ikon Film!
СообщениеДобавлено: 17 янв 2013, 17:11  Заголовок сообщения:
write to the PM Peter
memberlist.php?mode=viewprofile&u=2196
СообщениеДобавлено: 17 янв 2013, 17:22  Заголовок сообщения:
Yeap, that is true. For years I have been collecting such cameras and I try hard to learn as much Russian as I can. It is not easy though (you cannot teach an old dog new tricks) :)
Yes, indeed, but I have received it messed up and fell sorry leaving it on my desk like this.
How can one find the right position with a DSLR? Do I have to mount that lens on it? Is there an article about it?
Кузнецов Сергей писал(а):
Thank you, I have sent a PM to Peter too (I hope I am not anoying though :) )
Последний раз редактировалось Nikos72 17 янв 2013, 17:25, всего редактировалось 1 раз.
гугль переводчик небось или аналогичная прога :)
з.ы. аналогично периодически пишу в англоязычный мфленз не зная английского :)
СообщениеДобавлено: 17 янв 2013, 17:30  Заголовок сообщения:
This is very easy. Just take the lens in one hand and DSLR in another :) Yeap, it will be only "macro" mode, but anyway...
Zeiss Ikon Camera,
Zeiss Objektiv,
Zeiss Ikon Film!
СообщениеДобавлено: 17 янв 2013, 17:35  Заголовок сообщения:
Aha! Yes, I remember that trick!!! Thank you!!!
СообщениеДобавлено: 17 янв 2013, 22:37  Заголовок сообщения:
Amazing! An hour ago I had realized that the previous owner had the lens disassembled and put things back in the wrong way. The blades where incorrectly placed, the index that was moving the blades was upside down and there was one screw missing.
And ebay's description was as mint and tested!
It took me an hour to open it up and put things back correctly. The last step is to adust the lens.
СообщениеДобавлено: 18 янв 2013, 07:31  Заголовок сообщения:
Get in touch with Peter, I have gotten his own precious FED-atlas. He could not transform this piece of crap into a candy but at least it does work as good as it gets. I was not terribly impressed with it. And good grief you are not writing in ancient Greek :hihi:
СообщениеДобавлено: 18 янв 2013, 07:43  Заголовок сообщения:
Уважаемые ЧКД!
Я внимательно перечитал все посты Никоса из Афин и просмотрел
его фото на Фликре.
Задний элемент объектива по-моему, никто не трогал!
Все винты на месте и даже краска на них цела.
Таким образом его проблема - правильно поставить объектив на место?
Я так понял что он не знает в какую сторону его крутить .
Насколько я помню Атлас,там надо аккуратно вставить и повернуть по-часовой стрелке.
( Просто полного настоящего ФЭДа-Атлас у меня сейчас нет, а есть
сборная солянка из ФЭД-10 и верхней крышки Атласа,но всё настроено и работает :) )
У кого есть ФЭД -Атлас и кто может подсказать, как правильно поставить объектив?
СообщениеДобавлено: 18 янв 2013, 08:42  Заголовок сообщения:
Здесь есть обзор камер ФЭД-10/Атлас ЧКД risk_2000.
В инструкции к ФЭД10 запрещается снимать объектив для исключения разъюстировки дальномера. Реально данное запрещение действенно - действительно разьюстируется. И последующую юстировкку придется проводить с разборкой камеры.
Если не найдется владельца такой камеры, остается автору самостоятельно пробовать установить объектив на место и провести настройку дальномера при снятой верхней крышке камеры.
In fact, FED-Atlas is a fixed lens camera.
You must not disconnect lens from camera. It causes rangefinder disadjustment.
Curiously, if you need to adjust the rangefinder, you must disassemble the camera top.
СообщениеДобавлено: 18 янв 2013, 09:30  Заголовок сообщения:
Уважаемые ЧКД!
его фото на Фликре.
Hi Peter,
The photos are just from flickr from another's Fed Atlas. In my Fed I had discovered that:
1. The previous owner had the lens dissasembled and put the aperture blades in the wrong way.
2. That index ring that guides the aperture from fully open to fully closed was placed upside down (!!!). Apparently with the blades not closing he could not turn the lens.
3. There is one screw missing from the element on top of the blades (there are only two screws).
What I did now is:
1. I have opened the lens.
2. Spend two hours figuring out how to properly place the aperture blades.
3. Put all things back by using that photo on flickr as a reference (I wish that lens was mine :) ).
4. Mounted the lens with all set at that position as in the photo.
It looks that everything is o.k. now, but how about focus? Is there a correct depth to which I should screw in the inner tube of the lens?
In the lessons of ancient Greek I was out playing ball with my friends :lol: I have to confess that I was not the best student in my class. My mind was always far away...
СообщениеДобавлено: 18 янв 2013, 11:32  Заголовок сообщения:
Nikos72
In your signature Set camera FED TSVVS. Can display its image, just wondering
СообщениеДобавлено: 18 янв 2013, 11:51  Заголовок сообщения:
evgenys2005ss писал(а):
Nikos72
Sure! I will take photos this weekend and post them.
СообщениеДобавлено: 18 янв 2013, 13:10  Заголовок сообщения:
Nikos72!
Я всё-таки далее напишу для Вас по-русски,чтобы точно
выразить свои мысли.
Вам придется потрудиться с переводом самому....
Итак:
- Я понял ,что фото на Фликре были для Вас просто как эталон
и Вы не показывавали реальные фото Вашего объектива
- Вы уже собрали правильно диафрагму и поставили
задний линзоблок
-Вы уже присоединили объектив к корпусу камеры и
теперь Вам нужно правильно настроить Ваш АТЛАС....
:roll:
Тогда Ваши дальнейшие действия:
1.Проверьте обязательно бесконечность при открытом
затворе по матовому стеклу на направляющих кадрового окна.
Если всё ОК- двигаемся дальше.
Если бесконечности нет, ищем причину- где неправильно собрано.
2.Если бесконечность есть,желательно ( но не обязательно) проверить
соответствие шкалы расстояний реальной фокусировке по матовому стеклу.
3.Далее настраиваем дальномер:
- начинаем со сведения пятна по вертикали,
далее сводим дальномер на бесконечности,
и проверяем всё время по- матовому стеклу и совпадению пятна на
10 м, на 3 м и на 1 м.
Я делаю так....
Удачи!
СообщениеДобавлено: 18 янв 2013, 14:40  Заголовок сообщения:
Thank you very much Peter!
I'll do this as soon as I get home.
Thank you very much for dealing with me,
Nikos.
СообщениеДобавлено: 18 янв 2013, 15:54  Заголовок сообщения:
Nikos.
You are welcome !
СообщениеДобавлено: 22 янв 2013, 14:44  Заголовок сообщения:
Nikos72
Hi, I did not forget you. I just had no chance of taking photos this weekend. I will try to do so tomorrow if I get away from work early.
Nikos.
You are welcome !
Hi Peter,
Now it is perfect! A million thanks for your invaluable help. Here it is, all in place, lightmeter does not work, but who cares:
Fed Atlas by Nikos.K., on Flickr
Сейчас этот форум просматривают: нет зарегистрированных пользователей и гости: 36
