Текущее время: 06 авг 2025, 10:08
СообщениеДобавлено: 18 янв 2009, 10:57  Заголовок сообщения: Пусть будет в этом разделе :) (Проявка в кофе №567888)
http://bigrasta.livejournal.com/36653.html
СообщениеДобавлено: 18 янв 2009, 11:02  Заголовок сообщения: (no subject)
Здесь, наверно, человек начитался
http://art.photo-element.ru/ts/caffenol/caffenol.html
http://www.spb-gmu.ru//index.php?option ... Itemid=516
СообщениеДобавлено: 18 янв 2009, 17:13  Заголовок сообщения: (no subject)
откуда то из rec.photo.darkroom давно сохранено:
----cut on----
Caffenol Film Developer Formula
Caffenol
Caffenol film developer
Water8 oz
Arm & Hammer Washing Soda2 tsp (level)
Folger's Coffee Crystals4 tsp (slightly rounded)
Mixing instructions: Mix soda until completely dissolved and
solution is clear. Add coffee, mix until all grittiness is
gone and solution is uniform, let stand 5-10 minutes until
microbubbles clear. Use within 30 minutes.
Dilution: Use undiluted
Starting point development time: 30 mins
Notes: Gives imagewise stain and general (fog) stain.
Caffenol C
Caffenol C film developer
Water8 oz
Arm & Hammer Washing Soda2.5 tsp (level)
Ascorbic Acid or Erythorbic Acid (97%)1 g*
*1 g = approx. 1/4 tsp
Starting point development time: 12 mins
Notes: Expect slight film speed increase (1/3 to 2/3 stop) and
little or no stain. Reduce agitation to eliminate flow marks.
Caffenol LC
Caffenol LC low contrast film developer
Water8 oz
Folger's Coffee Crystals2 tsp (slightly rounded)
Notes: Low contrast developer. Use with microfilms to give
pictorial contrast. Mild imagewise stain, little or no general
stain.
This information was kindly provided by Donald Qualls. For
more details please visit Donald's page of Dilutions and Times
Caffenol LC+C
Caffenol LC+C low contrast film developer
Water8 oz
Arm & Hammer Washing Soda4 tsp (level)
Ascorbic Acid or Erythorbic Acid (97%)0.26 g
microbubbles clear. Mix 1/4 tsp ascorbic acid in one quart
water, and use 8 ounces for the developer. Use within 30
minutes.
Starting point development time: 20 mins
Notes: Speed-enhancing low contrast developer. Use with
microfilms to give increased speed with pictorial contrast. No
detectable stain.
----cut off----
СообщениеДобавлено: 18 янв 2009, 17:40  Заголовок сообщения: (no subject)
Я как шутку пОстил! :shock: Кто-нибудь из присутствующих сам непосредственно пользовал?
СообщениеДобавлено: 18 янв 2009, 18:20  Заголовок сообщения: (no subject)
когда нашёл эти рецепты попробовал один раз
полутонов не получил вообще
соду правда обычную пищевую использовал
надо время явно больше чем указанные 20мин
но 8часов это как то слишком
на d-76.ru в форуме вроде бы это обсуждалось
когда припрёт тогда будет смысл морочиться
СообщениеДобавлено: 18 янв 2009, 18:24  Заголовок сообщения: (no subject)
Вы думаете припрет?
Я уж D-23 намешаю
2 ингредиента, качество выше
СообщениеДобавлено: 18 янв 2009, 19:22  Заголовок сообщения: (no subject)
Где- нибудь .... на пленэре :roll: Поужинал - остатки кофе в бачек, а с утра с этим бачком в кусты отошел и готово!
СообщениеДобавлено: 18 янв 2009, 19:26  Заголовок сообщения: (no subject)
а вот что с фиксированием солёной водой?
реально и насколько стабилен результат?
СообщениеДобавлено: 05 июл 2010, 14:06  Заголовок сообщения: (no subject)
Я проявлял в соде и лимонной кислоте, правда засветил пленку, =(
обираюсь попробовать ради эксперимента и другие рецепты, отпишусь как сделаю, пока апну тему, чтобы не забыть=))
Зенит11+Юпитер9+Юпитер11А+Юпитер37А+Индустар 61Л\З+Монокль из Гелиос44м; Зокий; ФЭД3; Смена 8М; Чайка3
СообщениеДобавлено: 05 июл 2010, 14:19  Заголовок сообщения: (no subject)
пусть еще попробует фиксировать в моче
СообщениеДобавлено: 05 июл 2010, 15:16  Заголовок сообщения: (no subject)
Urine as a developer
http://photo.net/black-and-white-photo-film-processing-forum/00Wnnn
СообщениеДобавлено: 05 июл 2010, 22:58  Заголовок сообщения: (no subject)
На Д-76 пошли даже дальше
http://d-76.ru/main/forum/index.php?showtopic=432 :D
СообщениеДобавлено: 06 июл 2010, 09:39  Заголовок сообщения: (no subject)
тему переименуй, автор
СообщениеДобавлено: 06 июл 2010, 10:24  Заголовок сообщения: (no subject)
кроме шуток - на листе zenit camera group один из участников регулярно публикует примеры фотографий, сделанных в каффеноле. он предупреждает, что эта хрень нереально воняет. примеры тут: http://www.flickr.com/photos/joaofreita ... 092011983/
СообщениеДобавлено: 06 июл 2010, 10:37  Заголовок сообщения: (no subject)
эта хрень нереально воняет/
Запах творчества приятен всегда
СообщениеДобавлено: 06 июл 2010, 14:42  Заголовок сообщения: (no subject)
Вообще-то тема не нова. В 19-м веке пытались (до применения желатины) заменить чем-нибудь мокрый коллодий. Нужно было что-то похожее на эмульсию для сухих пластинок. Так вот, была масса рецептов с чаем, кофе и даже пивом - лучше всего подходил портер. Причём это не первоапрельский розыгрыш - я давно хочу материалец подготовить.
