Обзоры
Просмотры
Дата публикации товара
0
45764
Сб Апрель 20, 2013
Рекомендовано
Средняя цена
Средний рейтинг
Пока отсутствуют
Пока отсутствует
Пока отсутствует
Описание:
The Magnifax 4a enlargers have been designed to produce black and white or color photographs from negatives up to 65 x 90 mm and 70 x 70 mm or slides up to 7 x 7 cm. It is possible to use these enlargers with wide variety of accessories. The device is available in three modifications:
Magnifax 4a for black and white (392 211 500 615) photography featuring direct correction for converging verticals and special color filters holder to produce color photographs. Condenser system consists of double planconvex lens with built in thermal filter. The lamp is opaline 150W/E27 fitting with 70 mm envelope (not included). Diffuser is inserted in filter holder. Negative carrier is metal and with split line focusing system. Enlarger is equiped with micro focusing system.
Magnifax 4a Color 3 (392 211 500 604) for color photography featuring the Meopta Color 3 special color head enabling stepless filtration adjustment using the subtractive method. Negative carrier is metal and with split line focusing system.
Magnifax 4a Color 4-ES (392 211 510 624) for color photography featuring the Color 4-ES special color head enabling stepless filtration adjustment using the subtractive methods. Negative carrier is metal and with split line focusing system.
The Magnifax 4a enlarger allows image restitution meeting the Scheimpflug condition. Swiveling the device by 90° provides wall projection. Swiveling the enlarger by 180° provides floor projection of high standard enlargements.
Other specifications
Maximum negative size: 65 x 90 mm
Lens: available separately
Baseboard: wood, natural grain and color 600 x 600 mm
Baseboard magnification: 0.9x - 7.3x
Height overall: 1375 mm
Depth overall: 943 mm
Weight: 18.8 kg
Документация:
(рус.) (eng.)
Примеры:
фотографии - < отсутствуют >
Powered by: Reviewpost PHP
Copyright 2008 All Enthusiast, Inc.
Купить Бокалы Chef & Sommelier - официальный магазин.
