Текущее время: 24 фев 2026, 03:19
Начать новую тему Ответить на тему  [ Сообщений: 25 ]  На страницу Пред.  1, 2
СообщениеДобавлено: 13 окт 2009, 23:37  Заголовок сообщения: (no subject)
Я бы не спешил с шириками на М9. Почитайте вот эту ветку
http://www.l-camera-forum.com/leica-for ... -18mm.html
Там выясняются очередные проблемы у лейки, как обычно :shock:
I've done some further work on this question, and in summary:
1. I think the issue that we are seeing is caused by de-centering between the lens and sensor, leading to asymmetries in vignetting. It is not clear where exactly the de-centering is coming from, but the most likely explanation is manufacturing variations in the lens. This de-centering does also exist on the M8, but the impact is small enough to mostly be invisible.
2. It also seems likely that there is variation with aperture; the problem seems to get worse at larger apertures.
3. Leica's best course to fix the problem, or at least make it less visible, is probably just to reduce red correction for the 18mm. This will leave the right hand side of the images Tim showed under compensated, but that's a lot less visible that over compensation. This can easily be done in firmware.
4. CornerFix, in its current form, can't fix this problem. The reason is that CornerFix is designed only to deal with symmetrical vignetting. I'm currently working on a new version that removes this restriction.
For those interested in a whole bunch of charts, and a far more detailed explanation, I've posted one here: ChromaSoft: Vignetting Correction Issues on the Leica M9
BTW, I don't know why this happens mostly on the left hand side of images. I can only speculate that it has something to do with either the way Leica build and calibrate lenses, or the way the M9 is built.
Sandy
СообщениеДобавлено: 13 окт 2009, 23:50  Заголовок сообщения: (no subject)
Еще хочу добавить - если 28й вполне рабочий, в смысле относительно часто используемый, объектив, и поэтому на него жаться не стоит, то сверхширики - объективы, все же, достаточно специфические, не на каждый день, что называется. Поэтому, опять же имхо, не стоит палить на них каких-то больших денег. Не помню точно, сколько стоит 15-й цейсс, но помню, очень немало.
СообщениеДобавлено: 14 окт 2009, 01:37  Заголовок сообщения: (no subject)
Вообще-то есть два предпочтительных ряда:
первый: 12-17(18 )-24(25)-35-50-70(75)....
второй: 14-20(21) - 28-40-55(58 )-80(85)...
Лично я предпочитаю первый ряд. В качестве компромисса купил никкор 15 мм и быстро понял именно то, о чём Вы говорите: это и не 12, и не 17... Для большинства съёмок был бы лучше 17-18, но для экстрима нужен 12.
Только вот вопрос: а как у него с разрешением по углам?
СообщениеДобавлено: 14 окт 2009, 01:59  Заголовок сообщения: (no subject)
Естественно, фойхт - это фойхт, да еще 12мм, в углах сумасшедшего звона нет, надо быть реалистом, но поверьте, откровенного мыла тоже нет. Нормальные углы, короче.
На самом деле, он, по-моему, все же 13мм. Производители всегда привирают. Как-то попадался какой-то проверочный тест, но тесты я не коллекционирую, дать ссылку не могу. Но все равно - угол обзора у него просто бешеный.
СообщениеДобавлено: 15 окт 2009, 01:01  Заголовок сообщения: (no subject)
Понял...
