Текущее время: 21 дек 2025, 20:22
Начать новую тему Ответить на тему  [ Сообщений: 222 ]  На страницу 1, 2, 3, 4, 5 ... 12  След.
СообщениеДобавлено: 19 май 2009, 20:24  Заголовок сообщения: Voigtlander Nokton 50/1.1 - первые факты.
Начали за здравие: http://www.rangefinderforum.com/forums/ ... hp?t=74565
"Сказали мне что Косино выпустит..."
...и завершили на "отличененько":
Indeed, there is a 50mm f1.1 from Cosina. I did shoot with it in March when we were in japan. Of course, i had to keep quiet about it, which is not easy!
It is a very sweet lens, slightly smaller than an older style Noctilux, 58mm filter thread. Weight seemed to be similar, or slightly lighter. The prototype looked a bit like a Nokton 50f1.5 on steroids. Similar knurling on the focus and it "sat" well in the hand when on the camera. There were two versions of the hood. One was a smallish, thread mount one, slightly flared (minimum intrusion into the finder of the M2 and ZM) and the other one was a larger diameter one with a clamp-on screw.
Image quality was very good. For obvious reasons I shot most everything at f1.1 or there-abouts. The corner fall off is less than on the Noctilux f1.0- looks to be around 1,0-1.5 stops. Less of peering through a tunnel as the Noctilux tended to create. Sharpness at f1.1 is very good - I did not do "resolution" tests - but looking at the negatives - I would have no problem blowing them up to 11x14 or 16x20 without having the lens being the limiting factor. I did shoot most of the pictures with Acros 100 and developed them in Beutler. This is a combination that takes "no prisoners" in terms of sharpness and contrast.
The price seems to be set at around $1100 - but that might depend on exchange rate too.
I will post some shots from it later today.
What I liked is the fact that a/ a bit more compact than the Noctilux and b/ apart from being very good at f1.1 - the quality when stopped down held up and it is nice and sharp throughout the whole f-stop range. This means to me that it could do duty as a "standard" 50mm without loosing image quality in bright light and on the "dark" side.
(с) TomA
Т.е. Выпускается 50/1.1 сверхсветосильный штатник, чуть меньше старого Ноктилюкса по размеру. Пристоен на ф/1.1, отменен на всех последующих диафрагмах.
Цена: $1100 +|-
Семплы с оного: http://www.flickr.com/photos/rapidwinde ... 278125070/
(с) TomA
Последний раз редактировалось QUAsit 19 май 2009, 21:23, всего редактировалось 1 раз.
СообщениеДобавлено: 19 май 2009, 21:04  Заголовок сообщения: (no subject)
Особо интересно на него посмотреть на 8-11, начиная с 20 на 30.
Сообщать мне о получении ответа!
СообщениеДобавлено: 19 май 2009, 21:26  Заголовок сообщения: (no subject)
http://www.flickr.com/photos/rapidwinde ... 278125070/ сцылко со снимками с него достойна быть помещена в эту тему.
как вам, о широкая общественность?
СообщениеДобавлено: 19 май 2009, 23:43  Заголовок сообщения: (no subject)
Stjarna писал(а):
http://www.flickr.com/photos/rapidwinder/sets/72157616278125070/ сцылко со снимками с него достойна быть помещена в эту тему.
/бросил копить на зоннар и начал копить на новый ноктон/
широкая общественность одобряэ
СообщениеДобавлено: 20 май 2009, 01:33  Заголовок сообщения: (no subject)
Mr Kobayashi сам доволен!
Даа-а-а , внушает! :)
СообщениеДобавлено: 20 май 2009, 09:47  Заголовок сообщения: (no subject)
http://leica.lensinfo.net/read-194.html
СообщениеДобавлено: 20 май 2009, 10:46  Заголовок сообщения: (no subject)
Чёт, судя по рисунку, ему далеко-далёко до Накта :roll:
... и даже до 40-го Ноктона :wink:
СообщениеДобавлено: 20 май 2009, 11:50  Заголовок сообщения: (no subject)
http://www.rangefinderforum.com/forums/ ... hp?t=74616
СообщениеДобавлено: 20 май 2009, 12:10  Заголовок сообщения: (no subject)
Игорь Евтихов писал(а):
http://www.rangefinderforum.com/forums/showthread.php?t=74616
Цена заявлена вроде 125000 йен?
При этом 35/1.2 на этом сайте оценивается в 135000.
Смотрим на Ганди и получаем за новый ноктон примерно 820 баксов, весьма заманчиво... Том А о примерно $1100 писал вчера ...
СообщениеДобавлено: 20 май 2009, 12:22  Заголовок сообщения: (no subject)
по моим подсчетам 1250 usd получается
СообщениеДобавлено: 20 май 2009, 12:48  Заголовок сообщения: (no subject)
Это да. Если по оф. курсу перевести цену с сайта производителя. У дилеров цены отличаются как правило (на оф. сайте косины 35/1.2 стоит 135000 йен или, по курсу, примерно $1400, Ганди его продает за $879, Чифф из Сингапура еще на $100 дешевле :wink: ).
СообщениеДобавлено: 20 май 2009, 12:53  Заголовок сообщения: (no subject)
Я согласен на оба варианта. Главное чтобы объектив хороший оказался)
СообщениеДобавлено: 20 май 2009, 16:39  Заголовок сообщения: (no subject)
Вот и сбыча мечт приходит. Надо бы в цвете на него посмотреть, но думаю буду брать полюбому.
СообщениеДобавлено: 20 май 2009, 17:22  Заголовок сообщения: (no subject)
А чего в нем хорошего? :oops:
СообщениеДобавлено: 20 май 2009, 17:30  Заголовок сообщения: (no subject)
Цена и светосила, не?
Я конечно понимаю, что кому денег девать некуда все равно купят ноктилюкс и будут гнобить ноктон ;)
СообщениеДобавлено: 20 май 2009, 18:36  Заголовок сообщения: (no subject)
Еще Бесса с ним не будет "мордой" вверх кувыркаться :D.
СообщениеДобавлено: 20 май 2009, 18:42  Заголовок сообщения: (no subject)
зачем обывателю такая светлая сила? у меня вон одно стекло 2.4 второе и третье 4, а пятое вообще 8 и ниче, снимаем как-то.
СообщениеДобавлено: 20 май 2009, 20:35  Заголовок сообщения: (no subject)
Для съемки "мечтательных" портретов а также (для особо продвинутых) для съемки стрита ночью.
СообщениеДобавлено: 20 май 2009, 21:13  Заголовок сообщения: (no subject)
Не все ценят Ноктилюкс за его цену - простите за каламбур - у него еще и другие достоинства имеются. В частности, неповторимый рисунок. А ежели кому охота стрит ночной поснимать, то дешевле, как мне кажется, пленку приобресть "позлее". А для съемки мечтательных портретов 75-й люкс вне конкуренции. Пока что то, что выставлено на Фликре - не впечатлило.
СообщениеДобавлено: 20 май 2009, 21:17  Заголовок сообщения: (no subject)
аналогично-с
